Notification sound (calendar
Hi
I would like to use two different sounds for my calendar events and regular notifications.
(an time-sensitive-event is much more important than a random SMS)
But I can’t on Iode. It seems to be standard behaviour in many commercial OSs. As the calendar is shipped integrated with iode, I believe that at least for the calendar there should be the option to have another notification-sound.
(per app flexibility would be bonus, but for me calendar would be crucial)
Thank you
Maybe another calendar app would have more detailed notification and other options?
But I think this is already possible: If you go to the Calendar App > Top Left 3 bars > Settings" and then select the specific calendar > “Manage Notifications” you can change it away from the default sound.
So in short you can customize the sound per calendar.
