Hello, first of all I would like to thank you for this great ROM. I would like to make a suggestion. Before I installed Iode OS, I used LineageOS 19. And I liked the keyboard better than OpenBoard. Unfortunately you can not install it without root. Could you give the user the option to choose between OpenBoard and LineageOS keyboard?
Hi, try FOSS keyboard from SimpleMobileTools: Simple Keyboard
By the way: What is better about LOS AOSP Android keyboard?
