Iode OS for Xperia XZ1 Compact
Hello, I’m new to this community and I was hoping to download iode os on a xperia xz1 compact. When I checked the main site I only see support for the xz1 but not the compact. I was hoping someone here could verify if it works.
Thank You.
I would love to see iodé running on the XZ1 Compact. If the source were open, I would happily spend tim building it :slight_smile:
I thought you are using /e/?
I am at the moment, because I can build /e/ for this phone. I would prefer to have an OS that doesn’t have a lot of forked apps that I don’t want or need :slight_smile: I would be happy to build iodé if the source was open.
And on iode all preinstalled apps are uninstallable without usind adb commands :wink: even microG
And no e.cloud ecosystem
Actually, I like - and use - the ecloud ecosystem, which is perfectly usable with standard apps like NextCloud, sync and Notes apps, DAVx5 and ICSx5
I use a managed nextcloud, too
But not e.cloud. another German local carrier.
Is more flexible for me…
