Iodé doesn't detect/monitor apps? [SOLVED]
Hi there,
I noticed that only a few apps are detected and monitored by iodé app on my phone (~10% at the moment).
Most of them do not appear in iodé reports or streams.
If I get them uninstalled then reinstalled, they seem to be properly detected and monitored.
How come? I’m using iodéos 6.6.
I could reinstall them all, but it’s such a hassle to reconfigure… a workaround would be appreciated (is there a way to reinstall an app without uninstalling it first?).
edit
even preinstalled apps are not monitored…
I reset data in iodé general settings. This seems to have solved the issue.
I have seen a post that another person had to do this as well a while back. Not certain of the trigger. Was 6.6 the first install on your device, or was it upgraded to that from an earlier build?
My samsung s10e used to run iodé 4.x, so as an upgrade I had to make a clean install to iodé 6.6.
