My userdebug 7.3 builds are working “out of the box”, with no changes needed to vertificate handling (or anything else). So may well be jus an issue with user builds
I guess this is related to the certificates I use to sign the APKs shipped with Lineage/iodé in preparation to relock the bootloader. It is described in the Lineage wiki Signing Builds | LineageOS Wiki. I was thinking of giving it a try with completely new certificates for the APKs - maybe Bluetooth is working then again.
I had to do some spells to get Bluetooth working with Lineage 23.2. I’ll check tomorrow when I’m at my computer
OK. This was the issue that we had: Fix BT signing keys in 23.2 · Issue #858 · lineageos4microg/docker-lineage-cicd · GitHub
The fix was to change this line in our main build script to add the following three lines to `vendor/lineage/config/common.mk: (previously, it just added the first two lines)
PRODUCT_DEFAULT_DEV_CERTIFICATE := user-keys/releasekey
PRODUCT_OTA_PUBLIC_KEYS := user-keys/releasekey
PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES := $(dir $(PRODUCT_DEFAULT_DEV_CERTIFICATE))
Thanks a lot. I will give it a try this afternoon. My build yesterday with new certificates only wasn’t fixing the issue obviously.
Thanks a lot for the hint - it helped to analyse the issue after building it again.
I had the problem that the common.mk file is tampered all the time and the 3rd line is missing. Therefore I created a before.sh userscript which adds it again. Hope, that the Prepare build environment step does not use the common.mk settings as at this time it isn’t set yet. I also pulled the last version of the image. But I use the “pf-build-iodeOS” tag.
Unfortunately Bluetooth still refuses to work but I see the same error message as you described in your link. So it should be somehow related to this…
It took me a while to get the fix right. The key fix seems to be as described in this comment
As I understand it, the variable
PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATESmust contain exactly the value$(dir $(PRODUCT_DEFAULT_DEV_CERTIFICATE))– see here and here.
I changed our shell script to the following:
if [ "$android_version_major" -ge "10" ]; then
sed -i "1s;^;PRODUCT_DEFAULT_DEV_CERTIFICATE := user-keys/releasekey\nPRODUCT_OTA_PUBLIC_KEYS := user-keys/releasekey\nPRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES := \$(dir \$(PRODUCT_DEFAULT_DEV_CERTIFICATE))\n\n;" "vendor/$vendor/config/common.mk"
fi
which modified the file to read as I posted above. That finally allowed Bluetooth to work
Ah - that may be a problem: the needed change has not yet been merged to that branch. And as I use that branch for my iodé builds, I huess my 7,3 builds are also likely to be broken. I will test and see if I need to pull my recent 7.3 builds and re-do them with the fix
No that’s not a problem for our builds. Tested with 7.3 build for pdx357 and BT works fine, even though the config/common.mk does not have does not have the `PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES` line.
So it seems that BT is working in our unofficial 7.3 userdebug builds without the change. I can’t think of anything else to suggest - sorry!
@petefoth thanks for the heads up, sorry I didn’t reply earlier but my unofficial v7.3 for cheetah that I installed last week doesn’t have any bluetooth issues, as you now confirmed.
But for you or @Lakrimar can you give a quick check if OpenEUICC is installed on any of your unofficial iodéOS builds? I don’t see it on cheetah and still have the Google SIM Manager? If not a quick response I can move this to a new thread.
I have the issue open. It helps me to analyse the problem, eg. with logcat but also the locations of the PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES parameter.
Don’t worry. Thanks a lot for your effort. Maybe it is related to the lineage-priv folder which I use for the Apex keys. Beside the com.* certificates it also contains the releasekey, testkey and bluetooth key - even though that are the same as in the keys folder configured as container volume. The interesting part is that the key.mk file in the lineage-priv folder also contains the parameter for PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES.
Therefore my idea was to 1. change the parameter in that file and if that not works, 2. copy the override certificates for the package signing to the container volume for keys and 3. get rid of the lineage-priv folder totally.
I had a look on the tablet and the only EUICC related app I can find is com.google.euiccpixel.overlay.gs201. The Google Tablet does not have a cell modem and does not use a SIM at all so this function isn’t really used, right?
Yes of course. Sorry I forgot
I’ll check in with others.
No sign of it on 7.3 for pdx235 . Google SIM Manager is present, and searching in Apps for euicc shows only
jp.co.sony.mc.euiccmemoryrestorg.lineageos.euiccorg.lineageos.euicc.overlay.sony
Today I took the time to try out several approaches to get bluetooth working again.
I tried following without success:
- Within the
lineage-privfolder located insrc/vendorI changed thekeys.mkto point to user-keys as in thecommon.mkin the config folder (kept sources viaCLEAN_AFTER_BUILD=false) - I copied the generated override certificates
com.android....to the keys volume used by the container (kept sources viaCLEAN_AFTER_BUILD=false) - I deleted the
lineage-privfolder completely (kept sources viaCLEAN_AFTER_BUILD=false) - Performed a complete new build with deleted folders from
do_cleanupand withkeys.mksettings and APEX certificates - Performed a complete new build with deleted folders from
do_cleanupwithoutkeys.mksetings and without APEX certificates - Performed a complete new build with deleted folders from
do_cleanupand own certificates without APEX
Only with the copied certificate from AOSP src/build/target/product/security to the container keys volume bluetooth is working again.
Maybe it is related to an individual subject as I changed the KEYS_SUBJECT variable accordingly instead of using the default values…
Any thoughts on this @petefoth ^^^^^^^^ not sure if we need to do something at l4m?
I think not: there are two l4m issues relating to this (#786 and #868), and they both refer to making user builds, which we don’t do. Making user builds is ‘out-of-scope’ for l4m, unless someone can provide a PR with changes that are tested to work with user builds and to not break our userdebug builds.
I did have to make some changes to get BlueTooth working in our l4m builds (see #858), but thta change wasn’t necessary for our (my?) iodéOS builds.
As suggested by @petefoth I tried the new 7.4 build without the userscripts setting the PRODUCT_MAINLINE_BLUETOOTH_SEPOLICY_DEV_CERTIFICATES separately and bluetooth is still working. It seems it is more about the certificate subject which I’ve set individually instead of using the default generic one.
