Hi, I read that the latest version of iodé has the wide angle camera issue solved, however I just installed iodé on my new fp4 and I can only take pictures with a maximum resolution of 4000 x 3000 (12MP). And the minimum zoom is 1x while in the original app it was 0.6x.
Am I doing something wrong? Should I configure anything on the app to get the full 48MP and 0.6x zoom?
Also, is there any way to get the original camera app working on iodé?
To the best of my knowledge, no custom ROM can use a resolution higher than 12Mpx. This is not solved.
The wide angle should be accessible in the embedded camera only, there should be an icon (a camera and ‘+’): this does not show on your phone ?
Oh I understand, I didn’t see the icon with a camera and a plus sign, now I do, indeed the wide angle works.
Do you think it would be possible to unlock the full 48mpx with a magisk module?
I saw that some Xiaomi devices can be unlocked this way (eszdman's 48MP Fix Magisk Modules)
