Thank you very much Chris!
Unfortunately I always get the same result ![]()
Here is the log :
Résumé
./flash-all.sh
mke2fs 1.46.6 (1-Feb-2023)
Creating filesystem with 16384 4k blocks and 16384 inodes
Allocating group tables: done
Writing inode tables: done
Sending ‘metadata’ (76 KB) OKAY [ 0.002s]
Writing ‘metadata’ OKAY [ 0.005s]
Finished. Total time: 0.028s
Erasing ‘metadata’ OKAY [ 0.005s]
Finished. Total time: 0.006s
Info: Disable heap-based policy
Info: Debug level = 1
Info: Trim is disabled
Info: Set conf for android
Info: Enable Project quota
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 479891624 (234322 MB)
Info: add quota type = 0 => 4
Info: add quota type = 1 => 5
Info: add quota type = 2 => 6
Info: format version with
“6.5.0-26-generic”
[f2fs_init_sit_area: 640] Filling sit area at offset 0x00600000
[f2fs_init_nat_area: 674] Filling nat area at offset 0x01a00000
[f2fs_write_root_inode:1292] Writing root inode (hot node), 2c000 0 200 at offset 0x00180224
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c601, 0002c602
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180225
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c603, 0002c604
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180226
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c605, 0002c606
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180227
[f2fs_update_nat_root:1479] Writing nat root, at offset 0x00001a00
[f2fs_add_default_dentry_root:1676] Writing default dentry root, at offset 0x0002c600
Info: Overprovision ratio = 0.300%
Info: Overprovision segments = 351 (GC reserved = 340)
[f2fs_write_check_point_pack: 837] Writing main segments, cp at offset 0x00000200
[f2fs_write_check_point_pack: 993] Writing Segment summary for HOT/WARM/COLD_DATA, at offset 0x00000201
[f2fs_write_check_point_pack:1020] Writing Segment summary for HOT_NODE, at offset 0x00000202
[f2fs_write_check_point_pack:1032] Writing Segment summary for WARM_NODE, at offset 0x00000203
[f2fs_write_check_point_pack:1043] Writing Segment summary for COLD_NODE, at offset 0x00000204
[f2fs_write_check_point_pack:1051] Writing cp page2, at offset 0x00000205
[f2fs_write_check_point_pack:1071] Writing NAT bits pages, at offset 0x000003fe
[f2fs_write_check_point_pack:1092] Writing cp page 1 of checkpoint pack 2, at offset 0x00000400
[f2fs_write_check_point_pack:1111] Writing cp page 2 of checkpoint pack 2, at offset 0x00000405
[f2fs_write_super_block:1144] Writing super block, at offset 0x00000000
Info: format successful
Sending ‘userdata’ (97 KB) OKAY [ 0.003s]
Writing ‘userdata’ OKAY [ 0.144s]
Finished. Total time: 0.457s
Erasing ‘userdata’ OKAY [ 0.118s]
Finished. Total time: 0.119s
Sending ‘modem_a’ (102252 KB) OKAY [ 3.102s]
Writing ‘modem_a’ OKAY [ 0.135s]
Finished. Total time: 3.319s
Bootloader Version…: ripcurrent-14.1-11208047
Baseband Version…: g5300i-230927-231102-B-11040898
Serial Number…: xxx
Setting current slot to ‘a’ OKAY [ 0.085s]
extracting boot.img (64 MB) to disk… took 0.270s
Sending ‘boot_a’ (65536 KB) OKAY [ 1.928s]
Writing ‘boot_a’ OKAY [ 0.086s]
extracting init_boot.img (8 MB) to disk… took 0.098s
archive does not contain ‘init_boot.sig’
Sending ‘init_boot_a’ (8192 KB) OKAY [ 0.234s]
Writing ‘init_boot_a’ OKAY [ 0.014s]
extracting dtbo.img (16 MB) to disk… took 0.094s
Sending ‘dtbo_a’ (16384 KB) OKAY [ 0.496s]
Writing ‘dtbo_a’ OKAY [ 0.023s]
archive does not contain ‘dt.img’
extracting pvmfw.img (1 MB) to disk… took 0.016s
archive does not contain ‘pvmfw.sig’
Sending ‘pvmfw_a’ (1024 KB) OKAY [ 0.029s]
Writing ‘pvmfw_a’ OKAY [ 0.006s]
archive does not contain ‘recovery.img’
extracting vbmeta.img (0 MB) to disk… took 0.000s
Sending ‘vbmeta_a’ (8 KB) OKAY [ 0.001s]
Writing ‘vbmeta_a’ OKAY [ 0.004s]
extracting vbmeta_system.img (0 MB) to disk… took 0.000s
archive does not contain ‘vbmeta_system.sig’
Sending ‘vbmeta_system_a’ (8 KB) OKAY [ 0.001s]
Writing ‘vbmeta_system_a’ OKAY [ 0.004s]
extracting vbmeta_vendor.img (0 MB) to disk… took 0.000s
archive does not contain ‘vbmeta_vendor.sig’
Sending ‘vbmeta_vendor_a’ (4 KB) OKAY [ 0.001s]
Writing ‘vbmeta_vendor_a’ OKAY [ 0.004s]
extracting vendor_boot.img (64 MB) to disk… took 0.232s
archive does not contain ‘vendor_boot.sig’
Sending ‘vendor_boot_a’ (65536 KB) OKAY [ 1.961s]
Writing ‘vendor_boot_a’ OKAY [ 0.093s]
extracting vendor_kernel_boot.img (64 MB) to disk… took 0.165s
archive does not contain ‘vendor_kernel_boot.sig’
Sending ‘vendor_kernel_boot_a’ (65536 KB) OKAY [ 1.928s]
Writing ‘vendor_kernel_boot_a’ OKAY [ 0.087s]
extracting super_empty.img (0 MB) to disk… took 0.000s
extracting product.img (1264 MB) to disk… took 4.654s
[liblp] Partition product_a will resize from 0 bytes to 1325514752 bytes
extracting system.img (826 MB) to disk… took 3.111s
[liblp] Partition system_a will resize from 0 bytes to 867106816 bytes
extracting system_dlkm.img (10 MB) to disk… took 0.026s
[liblp] Partition system_dlkm_a will resize from 0 bytes to 10964992 bytes
extracting system_ext.img (406 MB) to disk… took 1.562s
[liblp] Partition system_ext_a will resize from 0 bytes to 425959424 bytes
extracting system_other.img (15 MB) to disk… took 0.069s
[liblp] Partition system_b will resize from 0 bytes to 16416768 bytes
extracting vendor.img (794 MB) to disk… took 3.260s
[liblp] Partition vendor_a will resize from 0 bytes to 833581056 bytes
extracting vendor_dlkm.img (26 MB) to disk… took 0.090s
[liblp] Partition vendor_dlkm_a will resize from 0 bytes to 27418624 bytes
archive does not contain ‘vendor_other.img’
Sending sparse ‘super’ 1/14 (254972 KB) OKAY [ 7.565s]
Writing ‘super’ OKAY [ 0.359s]
Sending sparse ‘super’ 2/14 (254972 KB) OKAY [ 7.952s]
Writing ‘super’ OKAY [ 0.348s]
Sending sparse ‘super’ 3/14 (254972 KB) OKAY [ 7.499s]
Writing ‘super’ OKAY [ 0.350s]
Sending sparse ‘super’ 4/14 (254972 KB) OKAY [ 7.823s]
Sending sparse ‘super’ 5/14 (254972 KB) OKAY [ 7.877s]
Writing ‘super’ OKAY [ 0.355s]
Sending sparse ‘super’ 6/14 (254972 KB) OKAY [ 8.021s]
Writing ‘super’ OKAY [ 0.352s]
Sending sparse ‘super’ 7/14 (254972 KB) OKAY [ 7.998s]
Sending sparse ‘super’ 8/14 (254972 KB) OKAY [ 8.018s]
Sending sparse ‘super’ 9/14 (254972 KB) OKAY [ 7.996s]
Writing ‘super’ OKAY [ 0.363s]
Sending sparse ‘super’ 10/14 (254972 KB) OKAY [ 8.117s]
Writing ‘super’ OKAY [ 0.349s]
Sending sparse ‘super’ 11/14 (254972 KB) OKAY [ 8.018s]
Writing ‘super’ OKAY [ 0.353s]
Sending sparse ‘super’ 12/14 (254972 KB) OKAY [ 8.016s]
Sending sparse ‘super’ 13/14 (254972 KB) OKAY [ 8.044s]
Sending sparse ‘super’ 14/14 (110164 KB) OKAY [ 3.456s]
Writing ‘super’ OKAY [ 0.178s]
archive does not contain ‘boot_other.img’
archive does not contain ‘odm.img’
archive does not contain ‘odm_dlkm.img’
Finished. Total time: 132.433s
< waiting for any device >
Finished. Total time: 29.025s
Warning: skip copying abl image avb footer (abl partition size: 0, abl image size: 1785856).
Sending ‘abl’ (1744 KB) OKAY [ 0.057s]
Writing ‘abl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl1 image avb footer (bl1 partition size: 0, bl1 image size: 16384).
Sending ‘bl1’ (16 KB) OKAY [ 0.001s]
Writing ‘bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl2 image avb footer (bl2 partition size: 0, bl2 image size: 536576).
Sending ‘bl2’ (524 KB) OKAY [ 0.018s]
Writing ‘bl2’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl31 image avb footer (bl31 partition size: 0, bl31 image size: 106496).
Sending ‘bl31’ (104 KB) OKAY [ 0.004s]
Writing ‘bl31’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gcf image avb footer (gcf partition size: 0, gcf image size: 8192).
Sending ‘gcf’ (8 KB) OKAY [ 0.001s]
Writing ‘gcf’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa_bl1 image avb footer (gsa_bl1 partition size: 0, gsa_bl1 image size: 32768).
Sending ‘gsa_bl1’ (32 KB) OKAY [ 0.002s]
Writing ‘gsa_bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa image avb footer (gsa partition size: 0, gsa image size: 348160).
Sending ‘gsa’ (340 KB) OKAY [ 0.013s]
Writing ‘gsa’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying ldfw image avb footer (ldfw partition size: 0, ldfw image size: 2392064).
Sending ‘ldfw’ (2336 KB) OKAY [ 0.078s]
Writing ‘ldfw’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying pbl image avb footer (pbl partition size: 0, pbl image size: 49152).
Sending ‘pbl’ (48 KB) OKAY [ 0.003s]
Writing ‘pbl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying tzsw image avb footer (tzsw partition size: 0, tzsw image size: 7917568).
Sending ‘tzsw’ (7732 KB) OKAY [ 0.242s]
Writing ‘tzsw’ FAILED (remote: ‘No such file or directory’)
Rebooting into bootloader OKAY [ 0.000s]
Finished. Total time: 0.050s
FAILED (remote: ‘invalid android images, skip locking’)
