since a few months I can’t download pdf documents from this Broker App. The error message is a few minutes delayed after clicking download and it says in the notification drawer:
Any idea what that could be caused by (probably something iode OS related)? I first suspected iode blocker, but also without blocking any requests the download still fails.
Is that a 3rd party download manager, or directly inside the Broker App, or instead just your standard browser notification? It could be the app doing the download does not have “storage” permission in the destination it is downloading to?
Did you check the iodé blocker “Stream” tab while trying to see if anything is getting blocked? Also do check the “long press app icon > App Info > Permissions” to make sure no permission is disabled that may be needed.
It was my VPN (Tailscale) in combination with Flatex usage of the AOSP DownloadManager.
The Downloadmanager doesnt use the default route for DNS resolving but pins itself to the network object of the requesting App → which is then my VPN and since my VPN onyl resolve VPN internal addresses it couldnt resolve the download domain.
After disabling the VPN for the app via Tailscales split tunneling the downloads worked again.
