[CUSTOM BUILD] Zinwa Q25 Pro (Q25) for iode 7.5
iode-7.5-20260604-Q25-custom.zip
https://sourceforge.net/projects/eosbuildsronnz98/files/OtherCustomROMS/iode/iode-7.5-20260604-Q25-custom.zip/download
Please see sources and install instructions including recovery here:
This device is officially supported by LineageOS
Use it at your own risk!
Please support the developer(s)!
A turning point. BlackBerry Classic Revived. The fact that the LineageOS Android distribution now supports a MediaTek SoC (Helio G99) is just as remarkable as the native signature spoofing support in LOS 23.2. For years, this had been strictly rejected.
I did also unofficial builds for Blackberry Key2 / Key2 LE for another custom ROM you’ll find in my Sourceforge repository
