Aurora app. Problem nach update auf iodé 7.7
Hallo!
Ich kann keine Apps, z.B. VLC für Android mehr herunterladen, z.B. VLC für Android. Es zeigen sich nur kleine rotierende Symbole. Gibt es eine Lösung? Betroffen ist der Aurora Store.
Hello!
I can no longer download apps, for example, VLC for Android. Only small rotating icons appear. Is there a solution? Hello!
I can no longer download apps, for example, VLC for Android. Only small rotating icons appear. Is there a solution? This issue is affecting the Aurora Store.
Hi i have a similar problem and after many tries it startet laoding but i honestly dont know why. Paypal for example had this for me :face_with_diagonal_mouth:
Was wurde denn ausprobier, um Downloads aus Aurora wieder zu ermöglichen?
What measures were taken to enable downloads from Aurora again?
Aurora geht wieder. Habe über die Smartphone “Einstellungen” in der Aurora App Speicherinhalt und Cache gelöscht!
Aurora is working again. I cleared the storage and cache in the Aurora app via the smartphone’s “Settings”!
For me the solution is to open the ‘App info’ and ‘Force stop‘ the app. I have to do this nearly every time I want to use the app.
Yes, it is needed often. I think (??) the reason is the “anonymous accounts” get blocked / disabled and thus need to be re-registered.
